Gas gauge
Old Jan 19, 2012 | 06:10 AM
  #11
Thux8's Avatar
I tapped into the wires Coming from the sending unit and ran my own wire to the gas gauge when I touched the wire to the little stud on back of gauge the fuel gauge went past the full mark... This tell ya anything?
Old Jan 20, 2012 | 07:26 AM
  #12
Did you tap into the wires right at the sending unit ? If so I would suspect you tapped into a ground wire instead of the signal wire. You didn't state in the original post what the gauge was reading, was it reading full or empty ? It does appear that the gauge is working. It does look like you may have to lower the tank and remove the sending unit .
You can hook up the wires to the sending unit with it out of the tank and move the float with the key on and the dash gauge should respond to whatever position you have the float in. That is the best way to confirm whether it is good or not working.
Old Mar 12, 2012 | 11:45 AM
  #13
christine's Avatar
Default gas gauge
I had that problem and had a hole in my float in tank. Still can't find one to match it, afraid if I put anything else in, the gauge won't read right. Thats a question??? need help. 88 econoline 350.v8 Tioga.
Old Mar 12, 2012 | 03:38 PM
  #14
Gary2Wheels's Avatar
I'm pretty sure Ford still offers just the float... if it's a metal float,it can be repaired.....be very careful to remove any gasoline in it,by heating it at low temperature slowly.Letting it heat up in the sun,or using a hair dryer would do the trick.Be careful of any gasoline vapors!Then it could be soldered.I know how pricey those tank units are,but check Ford Parts - Silver State Ford Parts ,they're pretty good.
Old Mar 16, 2012 | 10:23 PM
  #15
christine's Avatar
Default fuelpump
its a plastic float, already tried stuff from auto zone, to repair, they said it would work in gas tank, Ha, It just snaps on the end, simple but can't find one. Have tried all the salvage yards too. Thanks. I guess I'll try ford dealer.
blake
Aug 8, 2006 12:43 PM
blake
Aug 5, 2006 11:35 PM
jp_waltz
Apr 24, 2006 04:59 PM
brad14880
Apr 7, 2006 03:12 PM
