Heater cutoff valve
Old Apr 13, 2016 | 12:10 PM
eric hoffmeyer's Avatar
Default Heater cutoff valve
1999 F 350, 7.3 Diesel, 2WD 6 speed
Say a Youtube video where a guy put in a vacuum actuated valve to stop the flow of hot water into the heater unit.
This is supposed to make the AC provide more cold air because the heater core won't be filled with hot coolant.
Any words of wisdom on this subject?
Thank you!
Regards,
Eric
Old Apr 14, 2016 | 04:46 AM
Maybe can utter a few words, but don't know about the wisdom part !
The system was designed to provide dried heated air for the defrosters , so the A/C system was supposed to provide that via blend and directional doors in the ductwork.
Theoretically , the doors block the incoming/recirculated air from getting heated when not needed. You most likely could install either a manual or vacuum controlled heater shut off valve in the system, but when the coolant is circulating through the heater core , it is keeping sediment from building up in the core and hopefully preventing poor heater output problems. Not sure if the function control for the HVAC system has a provision for controlling any vacuum operated valve. I suppose a lot would depend on the temps where you reside. When the system is operating as designed there should not be a need for a coolant shut off valve, however, the choice is yours.
Old Apr 14, 2016 | 02:08 PM
Alanah_Rae's Avatar
Thanks for the post. well said !!
Old Apr 18, 2016 | 11:34 AM
Hanky,
Thank you and those ARE words of wisdom. I'm going to leave it alone!!
THankyou,
Regards
Eric
Old Apr 19, 2016 | 01:08 PM
Alanah_Rae's Avatar
Originally Posted by eric hoffmeyer
Hanky,
THankyou,
Regards
Eric
That's good to hear
corvairbob
Feb 10, 2014 06:29 PM
jenmes70
Jul 29, 2013 07:17 PM
pschuess
Sep 15, 2010 09:41 PM
firechief
Mar 4, 2007 05:30 PM
Auburn
Nov 5, 2005 08:06 PM
