fuel pump cutoff switch question
Old Feb 10, 2014 | 06:06 PM
corvairbob's Avatar
Default fuel pump cutoff switch question
i got this switch to install in my corvair fuel pump circuit. the numbers on the switch are one side it has pbt-gf15 and the other side is 990830c xf32-9341-aa it came from a mustang but not sure the year. it has a red button on the top i presume. when i shale it i feel a reverberation and if i shock it the red button pops up. but my question is this it takes quite a bit of shock to make the button pop up. it seems to me this should trip faster than that, even to the point of if i turn it upside down it should pop up. with the amount i have to bang it i think it will not trip when needed if at all. so is this really normal for that shock load on this switch? thanks
Old Feb 10, 2014 | 06:29 PM
In Ford lingo it's called an inertia switch.
When installed properly you would be amazed at how well it works.
Many cars that got tapped in a parking lot sometimes wouldn't start because the switch was tripped. It is meant to trip when forward motion stops abruptly. (Inertia)
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
Spaznaut
May 24, 2014 02:10 PM
pschuess
Sep 15, 2010 09:41 PM
