Help! with my 99 f250 superduty 7.3
Old Oct 18, 2021 | 06:31 PM
Brooks5's Avatar
Default Help! with my 99 f250 superduty 7.3
Hoping for some help with my 99 7.3 with 250,000+ miles
Getting codes:
P0472- Exhaust pressure sensor circuit low input.
P01247 Turbo boost pressure low.
P01248 Turbo boost pressure not detected.
It runs like **** aka no power when it's cold, will run a 2000 rpm and not break 20 mph. Slow to shift...
Runs fine once it's up to temp.
I replaced the exhaust pressure sensor and tube a couple years ago. (Wondering if it may need cleaned already?)
Replaced the crankshaft sensor a few weeks ago.
And the injector pressure sensor, if I remember right. about a month ago.
Strangely I'm getting no check engine dummy light.
I'm afraid I may be looking at the wire harness under the valve covers? But hoping for other things to try first.
Also would it be able to be narrowed down with a shop computer rather than this cheap code reader?
Any helpful direction would be very appreciated!
TIA!
Old Oct 19, 2021 | 09:58 AM
Reddog01's Avatar
Red face Turbo problems
Ford uses a twin turbo, one is for low end the other is for higher RMPs on my 6.4
Check low end turbo boost as the turbo could be stuck on the upper RPM mode.
Brooks5
Oct 18, 2021 06:09 PM
01dyna
Feb 29, 2020 10:19 AM
a****98
Sep 30, 2016 08:30 PM
Zippy
Mar 5, 2011 12:10 PM
Beater
Dec 10, 2006 03:50 PM
