Help please, starting problem 2009 F250
Old Aug 26, 2021 | 12:57 PM
ljinnc12's Avatar
Default Help please, starting problem 2009 F250
I'm having a problem with my 2009 F250 with 5.4 gas engine starting when at operating temps. When cold starts fine, but when hot it has no crank and no start. the lights on the dash come on as normal, just no crank, no clicking, nothing. I've replaced the ignition switch, starter and every fuse, relay and diode related to stating or cranking. I just don't know where to look next, can you help? Thanks is advance.
Old Aug 26, 2021 | 02:51 PM
If you had a multimeter or voltmeter , you could prove what I am about to suggest.
Poor quality connections are easy to find and verify with a meter, but since we don't have one, we need to start at a beginning.
Suggest you loosen and clean all connections starting at the battery . Both positive and ground connections.
Those connections will always be in the pix until eliminated.
Let us know how you make out with this, thanks.
Micky_Mike
May 13, 2016 05:19 PM
gmangree
Jun 13, 2011 05:44 PM
BJB
Feb 4, 2008 07:16 PM
grnded
Dec 1, 2006 05:40 PM
GilmoreL
Apr 16, 2006 09:35 PM
