Hesitation in rear tank
Old Aug 31, 2015 | 05:34 PM
austyn gubbei's Avatar
Default Hesitation in rear tank
Hey,
Im new to this forum but I need help with my problem. I have a 1995 ford f250 4x4 5.8 351w with an automatic and dual gas tanks. I bought the truck as a utility bed and took the bed off and put a regular bed on. while I had bed off I replaced both gas tanks and fuel pumps. after I got it on the road I filled up both tanks and I ran it on the front tank first and it road nice and smooth. But when I put it on the rear tank and go to take off it bogs down and barely moves . So I switched it to front tank with my foot still on the gas and instantly the truck takes off like a bat out of hell. Has any one else had this problem where it runs fine on the front tank but hesitates on the rear tank. I thought it might be fuel pump but its brand new. Please help me thank you.
Austyn
Old Aug 31, 2015 | 07:20 PM
After you confirm the connections supplying power and ground to the rear tank pump, it is possible the pump is defective. The better thing to do is rent a fuel pump pressure gauge that connects to the schrader valve on the fuel rail on the driver's side of the engine and confirm the pressure . Just compare it to the front pump pressure.
Old Sep 1, 2015 | 04:24 PM
Hi, hanky I will check to see if everything is connected right the ground may be the problem because I had problems with grounds in the truck before I will try it this weekend and let you know if it worked or not. thanks
borose
Jan 5, 2013 07:46 PM
kyle87
Sep 24, 2010 03:33 PM
THEGOOSE
Feb 22, 2009 10:45 PM
outdoornut42
Dec 14, 2007 11:21 AM
swamper8
Nov 14, 2005 05:03 PM
