my 93 f2504x4 5.8 351 is squeeking bad!!
Old Aug 27, 2006 | 01:49 PM
93f250xlt4x4's Avatar
Default my 93 f2504x4 5.8 351 is squeeking bad!!
i am having a squeeking noise that seems to be coming from my engine. i thought it was my idler pulley and my tensioner pulley so i replaced both. but the noise was still their then i put a new serpetine belt on. i had a local shop clean all the pulleys on my truck. the noise stopped for a couple of days but came right back again. the noise never dissapear whether at idle or cruising speeds. but at around 40mph it cuts out for like a half of a second but comes right back. i have no clue what is wrong with it please help me.
Old Aug 28, 2006 | 07:42 AM
94 4x4 ranger's Avatar
Default RE: my 93 f2504x4 5.8 351 is squeeking bad!!
When you say it cut's out. Does the noise cut out? Or does the engine cut out?
Old Aug 28, 2006 | 06:01 PM
Couple things to try...
If you don't have a listening stephescope, you can 'very carefully' place a tube or long screw driver ect against your ear, placed against the nose/rear case of the alternator, and also the water pump towards the front bearing area.. You can/could also pop the belt back off and give the water pump and alternator a spin and listen for your squeak/squeal.. Do all of these at what ever temp you hear the noise the most.. Also, listen at the base, and towards the main body of the distributor as the shaft/housing can sometimes run dry and will squeal/squeak intermitten, or full time.. Check the fan clutch as well..
Old Aug 28, 2006 | 06:11 PM
i did take the belt off and spun evry pulley and i just found the ac clucth bearing gone but i and some mechanics dont think that will make the loud squeek that i describe. evry pulley seems fine a shop used a stethoscope and suspected that it might be a power steering pump but they said it would make a very different sound and said no other pulley had any squeek to it. also every time i put a new belt on it theirs no squeek until a few hours in or the next day. i cant really tell if my pulleys can be misaaligned. but thankyou so very much and if you have anymore opinions please post them. thanks
Old Aug 28, 2006 | 10:06 PM
Probably depends on what 'gone' means as far as the AC bearing.. 'Most' times the/a bearing will growl, or make a whirring sound, but if heated enough, or dried out/galled, can make a squeal/squeak, or even drag the belt (or worse) if there's enough resistance.. Idlers usually will 'chirp', or might squeal if their real bad, but you've ruled them out with new.. Don't rule out the distributor sfaft/housing as a source until checked.. Has thrown many a tech.. If the squeal/squeak is constant, start the truck with the belt removed and if the sound is still there, it rules out and pulleys, drives, pumps, alt, ect.. Belt misalignment usually won't cause a belt to squeak/squeal, (especially new) but can shorten the life of one, and may shread one eventually which might cause a lack of contact/squeal..
Old May 14, 2011 | 12:21 PM
jimm's Avatar
Default Squeaking from aerostar distributor
Hello, I seem to be getting a squeaking sound from my my distrubutor in my 95 aerostar, its pretty loud. at first you would think its a belt, but when I took of the engine cover inside where the distributor cap is, you can hear it real good. I pushed on the distributor and the noise changed which leads me to believe it has something to do with the distributor. What can I do to fix this?
MrSauga
Sep 19, 2012 04:26 PM
rlpatte
Mar 31, 2012 08:45 PM
buckie
Apr 21, 2011 07:40 PM
Hbombmike
Sep 16, 2007 11:04 PM
93f250xlt4x4
Sep 12, 2006 03:56 AM
