OD2 Port cut out
Old Feb 10, 2017 | 12:12 PM
gcraftjr's Avatar
Default OD2 Port cut out
I have a 2010 F250 6.4 that I am trying to hook up a Bullydog tuner to. I went to hook it up and a previous owner has cut out the odb2 port. I got a wiring diagram from a mechanic friend with the color codes and pinout for the truck. However the wires that are hanging down where the port should be are not the same color as the printout from Mitchell. I have 2 different print outs. The colors on the printout are the same. only 4 wires in my harness match the printout. There are 16 wires hanging which is what should be in the port.
Anyone have any advise?
Old Feb 10, 2017 | 12:40 PM
Welcome to the site..
Printout match these?
Old Feb 10, 2017 | 05:23 PM
gcraftjr's Avatar
Yes they match that one exactly. My wires are not that color. There are 16 wires. I know that is where the port goes.. I cant seem to find the correct diagram anywhere.
Old Feb 11, 2017 | 09:23 AM
What are the colors/tracers your seeing?
Have pic of them?
Old Feb 12, 2017 | 03:37 PM
gcraftjr's Avatar
The colors in my truck are
Yellow/Green
Green/white
White/Orange
Tan/orange
Blue/white
Violet/Brown
Blue/Grey
Blue
Green
Grey/Violet
Violet/Orange
White
Brown
Grey/Orange
Could this wiring harness be one that was supposed to be in a 2011? The printout for a 2009 and 2010 is the same.
My mechanic friend says this is a pinout for a PTO System. This doesn't make sense to me.
Old Feb 13, 2017 | 09:31 AM
Here's the profile for 2011..
Old Feb 13, 2017 | 10:07 AM
gcraftjr's Avatar
Thanks. But I think I have solved the Mystery. The wires I was messing with do go to the PTO Brake system. I tore apart the bottom of the dash in frustration this morning and was able to find the ODB2 wires cut off from the port and stuffed up behind the center of the dash by the radio.. It amazes me that someone would be so retarded to cut that port out. I can finally wire the tuner up now. the color codes on the wires match the ones for a 2010. Thanks for all your help..
Old Feb 13, 2017 | 01:09 PM
Thumbs up
You bet,, not sure why myself wack'n the DLC off was of any benefit?!
Old Feb 13, 2017 | 07:39 PM
gcraftjr's Avatar
Got the ODB2 wired up and pulled the codes. Codes are for the EGR valves missing. My truck has the bypasses on it.
Hooked up the bullydog as well. Where can I get the custom tunes to turn off the EGR valves?
Robiel
Oct 26, 2014 08:14 AM
ac917x
Jan 15, 2012 06:12 PM
Bbarrier1
Jun 17, 2011 06:10 PM
artcat99zl
May 4, 2011 11:54 AM
shagwagon
Mar 5, 2008 09:33 PM
