Parking Brake pedal
Old Jun 1, 2018 | 06:21 AM
eric hoffmeyer's Avatar
Default Parking Brake pedal
1999 F-350 7.3 V8 Turbo 6 speed 2WD
The PB pedal jams in the up (released) position.
This is the 2nd PB assembly i have put in the truck.
I initially thought the cable inside the housing had frayed and jammed. No such luck.
I removed the PB lever assemble and could only replicate the malfunction by fooling around with the release "gear" and spring assembly. I lubed everything, put it back in and it worked once fine. Second application the the PB the pedal became jammed in the up position.
I am guessing the gear (and I guess a clutch) in the release device is getting stuck.
Any thoughts on how to fix this?
Thanks!
Eric
eric hoffmeyer
Mar 11, 2016 01:36 PM
Jackbado
Apr 18, 2013 09:42 AM
Thumpe
Mar 1, 2010 05:21 PM
guitarjrw
Aug 22, 2007 03:27 PM
jonas74
Aug 7, 2005 11:25 PM
