power folding mirrors
Old Oct 28, 2019 | 06:12 PM
Ray 2020's Avatar
Default power folding mirrors
Has anyone added power folding mirrors to a 17-19 F250 ??
Or does anyone have any information or know where I can some.
Thnk You.
Old Oct 28, 2019 | 06:48 PM
Yes, we have..
The problem is, mirror heads are about 1000.00 per side, plus the door modules, plus the control switches etc .
I checked into it, and guesstimated it at about 3500.00 for parts and programming..
Old Oct 28, 2019 | 07:22 PM
Ray 2020's Avatar
Default Mirrors
Yes, we have..
But if the motor is 12vdc and changes direction with reverse polarity. 2 new wires on the right pins of the 22 pin plug and a switch. Memory seats and mirrors would require a controler I agree.
But just power fold I think should be doable..
Aftermarket mirrors at 1AAuto are only 704 a pair.
I think pins 18 and 19 are for the power fold. The door module should send 12v to the motor I want to bypass the door module.
Last edited by Ray 2020; Oct 28, 2019 at 07:38 PM. Reason: Spelling and additional info
Old Oct 30, 2019 | 04:24 PM
Ray 2020's Avatar
Default schematic
Is there any place I can get a schematic or a pinout of the mirror and door module?
If I can get 12vdc and reverse the polarity to that motor I think I can make it fold and unfold with a double pole double throw switch.
Old Oct 30, 2019 | 09:00 PM
Correct,, pins 18-19 are fold motor control. You probably could scab in a manual momentary direction control switch. With the door module, one touch controls auto fold.
If you still need the connector pin out, let me know...
Old Oct 31, 2019 | 03:47 PM
Ray 2020's Avatar
Thank you Hayapower.
What about power telescope, is that another motor? What pins are they on?
I am seriously considering buying the ones from 1AAuto and an 8 to 22 pin adapter harness from ebay just to see if they will fold.
then run 2 sets of wires from the dash to the door.
And there's a company in Atlanta that sells brass gears to replace the plastic ones.
Tanks again.
Old Oct 31, 2019 | 11:07 PM
Yes,,
I sent you some schematics.. Let me know if you need anything else..
Old Apr 27, 2020 | 06:45 PM
Nd5047's Avatar
Default Folding mirrors
Tanks again.
any luck doing this? I’m considering adding power folds to my truck
a2t
Sep 25, 2023 04:08 PM
Ray 2020
Oct 28, 2019 01:00 PM
Jack's Big Rig
Apr 22, 2019 03:30 PM
Fordster100
Jul 13, 2018 07:56 AM
tyoder123
May 1, 2017 10:55 AM
