Radio problem
Old Aug 20, 2024 | 11:34 AM
oshowo's Avatar
Default Radio problem
17 F 350 crew cab diesel. Low miles. Radio won’t turn off!!! Any help?
Old Aug 20, 2024 | 12:20 PM
Do you mean while driving you tried to turn it off or engine off key out door locked but radio stays on?
If it's the latter, after door locked, let the radio runs, wait about one hour, is it still running? If that's the case it can be a relay problem, specifically a relay with timer that should go to sleep, say 15 minutes but unsuccessfully.
No idea how your radio work before please provide more info.
Old Aug 20, 2024 | 12:46 PM
oshowo's Avatar
it turns off when i open door, engine off
Old Aug 20, 2024 | 12:58 PM
oshowo's Avatar
Will come on and turn off with no key in ignition!
Old Aug 21, 2024 | 05:14 AM
On off sw on radio broken resulting in stuck on position.if you turn it off manually.
Radio will need to be removed to replace on/off switch. .
Accessory delay relay is cutting power to radio when it eventually shuts off..
Old Aug 21, 2024 | 07:20 AM
oshowo's Avatar
Thanks soo much
SkyDog
Feb 3, 2018 08:37 PM
Sophie Elizabeth
May 17, 2017 09:35 AM
hdandford
Sep 29, 2008 12:47 PM
hdandford
Sep 26, 2008 11:02 AM
kimsxr8
Apr 27, 2006 12:55 AM
