Randomly shutting off!
Old Dec 5, 2018 | 07:33 AM
Krista Shue's Avatar
Default Randomly shutting off!
96 Ford F-250 7.3 diesel shut off randomly while driving. Sometimes it will start the engine before it slows down. Right before it starts the “wait to start” light will illuminate. If it doesn’t start back up and you have to cycle the key the “wait to start” light will not cycle. After a few minutes the light will illuminate when the key is cycled and it will start. Already replace the cps this last weekend!
Old Dec 5, 2018 | 01:44 PM
Because the little things sometime escape our attention I have to ask; do you have a heavy key ring hanging on the key that is in the ignition when driving?
It is a little thing , but has been known to cause a vehicle to shut down when driving because it moves the key tumbler section of the switch and causes the engine to shut down. It does sound as if the key is getting turned off, maybe and maybe not.
Old Dec 5, 2018 | 04:26 PM
I don’t have a heavy key chain it’s just the key and an auto zone rewards card on it.
Old Dec 18, 2018 | 07:01 PM
So I’ve checked the connections and found out that the ignition switch connector isn’t making good connection. I got a new switch and installed it but didn’t help it much so started just wiggling the wires and it’s seems to be in the connector. Today I was driving it and it hiccuped but kept running then 200 ft later it had no power when you pushed the throttle and shortly after that the throttle stuck and I had to put it in neutral turn it off and played with the connector it eventually started back up and I took it straight home it dying on me 2 times within the probably mile I had to go home any other suggestions or a pin out for the ignition switch connector?
v8vega383
Mar 23, 2019 02:50 PM
boomboom1966
Feb 3, 2013 05:37 PM
Bronco1990Scot
Feb 1, 2011 03:18 PM
sludgemonger
Jan 12, 2011 10:42 PM
jjcast13
Feb 28, 2007 08:14 PM
