Reak brake adjusting star wheel
Old May 22, 2017 | 08:11 AM
eric hoffmeyer's Avatar
Default Reak brake adjusting star wheel
1999 F 350 Diesel, 2WD
Which way does the brake shoe star get rotated to move the shoes outward?
Does it rotate top to bottom or vice versa?
Eric
Old May 22, 2017 | 02:04 PM
Hi Eric,
The driver's side adjuster may turn clockwise and the passenger side adjuster turns the opposite way. Some arms that rotate the star wheel work lifting the arm others work lowering the arm.
Old May 23, 2017 | 10:46 AM
Hanky,
OK. Thank you.
It is tricky to see inside to observe what is going on.
Best wishes,
Eric
Old May 23, 2017 | 01:06 PM
Bilinde Whyatt's Avatar
It's always which ever way is the hardest for you to do...
I always have the same problem so that being said:
Turn the star-shaped adjuster a few times.
If it does not stop turning due to the pads hitting the drum, then turn the star in the other direction.
After the pads hit the drum, back the star wheel off by one click.
Good Luck
Polly
Aug 3, 2015 08:03 PM
jrskydawg68
Feb 20, 2009 01:01 AM
bafflingsteveo
Jun 23, 2008 10:54 PM
ecp1985
Feb 10, 2008 09:52 AM
Nick999
Jan 21, 2008 05:04 PM
