thermostat
Old Jun 1, 2021 | 10:27 PM
flatheadgary's Avatar
Default thermostat
i was going to get a new one and took out the old one. it doesn't have a temp on it. it's a stock '75 460. anybody have a geuss what it would be? it is not in the truck yet.
Old Jun 2, 2021 | 06:47 AM
There were generally 2 choices, one was a 195 degree thermostat which brought the temp up higher and helped the engine run more efficiently plus provided better heat if you lived where it got pretty cold during the winter.
The other choice was a 180 degree thermostat which opened sooner , still provided decent heat and met the requirements for operating temperature.
My suggestion is someone evidently installed a cheap thermostat and it made no difference to them.
Good quality thermostats always have the opening degree numbers stamped on them usually on the circular bottom center of the capsule..
Old Jun 2, 2021 | 10:37 PM
thanks hanky. i live in a desert so i will go with the 180.
Andrew Frazier
Dec 14, 2019 09:17 PM
Czecher01
Jan 1, 2013 06:32 PM
petem
Jan 13, 2012 06:09 PM
taddey@gmail.com
Feb 1, 2010 06:42 AM
SteveS12
Apr 17, 2006 12:04 AM
