Trailer Brake Problem
Old Jan 20, 2006 | 05:31 PM
DSmith's Avatar
Default Trailer Brake Problem
Have problem with brake indicator or F350 when towing a 5th wheel trailer. It is intermittent problem. Shows no brakes and then will turn green - showing brakes on trailer. Have checked all wiring and Ford dealer has checked indicator on truck end. Anybody else have this problem? What did you find?
Old Sep 28, 2006 | 10:23 PM
12880tom's Avatar
Default RE: Trailer Brake Problem
I have a F250 the trailer warning lite comes on goes off then may stay on and i have no brakes at all i took it to a ford dealer several times they said it was the camper the camper store checked the trailer several times towed it with a different truck not intregated trailer brake but a f250 truck and had no problems ford said tough luck. hope you get yours fixed iam going to put a after market on mine
Old Oct 16, 2006 | 02:44 PM
12880tom's Avatar
ORIGINAL: DSmith
I replied to your problem once, after a complete recheck of my camper,I found out there was a short in my brake wiring inside the wheel of the camper. The truck picked it up, but to find the problem,the wheels had to be jacked up and the test box hooked up. The wheels spun by hand and the test box turned on it showed which wheel had the short. The bad part was the truck after a few beep alert's would disable the brake controller and you have no trailer brakes I did not try the slide switch manually to see if it worked it my have. Hope this helped
rdandcc
Nov 15, 2011 09:04 AM
93f250xlt4x4
Jul 3, 2008 10:02 AM
akilgore
Sep 26, 2007 02:18 PM
floyd
Aug 11, 2006 01:29 AM
scott
Jul 25, 2006 12:32 AM
