Ungehetoing exhaust
Old Apr 7, 2022 | 11:26 PM
ggenovez's Avatar
Default Ungehetoing exhaust
Hi all,
I picked up a 2008 F350 Dually extended cab, long bed, turbo diesel. Unfortunately it has a smokestack through the bed. I need the full length bed so I need to remove the smoke stack. Looks like the flange from the exhaust manifold is still intact. What do I need to get it back to a regular exhaust. Looking for cheap and good.
Much appreciated.
Old Apr 8, 2022 | 02:20 PM
Your best bet is to go to a dealership and get an idea of now many pieces you will need to change the exhaust pipe routing.
Once you have that info, you can either get it from a dealer or shop around and try to accumulate the pieces at a price that you like Good Luck.
Old Apr 8, 2022 | 02:23 PM
ggenovez's Avatar
Thanks Hanky. Looks like the DPF is gone and ford no longer makes it. So I'm guessing they did a DPF delete so I'll probably just run it straight out the back
green94f150
Mar 27, 2024 07:17 PM
dmcfx4
Oct 22, 2022 04:12 AM
HandyMoe
May 28, 2015 04:14 PM
thebeebs
Jul 15, 2013 11:09 AM
fordman87
Oct 7, 2005 07:40 PM
