Five Hundred Trans fluid change
Old Jan 8, 2022 | 04:24 PM
  #11
skarz's Avatar
Can someone please set the record straight on the transmission fluid filter? I got one guy on a FB group stating he just replaced his filter by dropping the vertical 'pan' on the front of the transmission. He referenced part Duralast Automatic Transmission Filter TF445 from AutoZone. Then I read in comments you are not supposed to replace that filter. What gives?
BTW vehicle in reference is the 2005 Five Hundred 6 speed Aisin.
Old Jan 8, 2022 | 08:02 PM
  #12
scott.butler4's Avatar
That filter you linked states its for the 12 bolt pan, I do not believe either of the two transmissions have 12 pan bolts. I know the CVT transmission has a filter, the Aisin transmission does not show a filter in the Ford workshop manual.
Old Jan 11, 2022 | 01:09 PM
  #13
RodrigoM's Avatar
Sounds like a good mechanic for warning you and not just doing the job for money. Any updates?
Old May 6, 2022 | 08:12 AM
  #14
transamlarry's Avatar
To access the drain plug on the 6-speed, do I have to remove the battery and all the stuff there?
Old May 7, 2022 | 10:19 AM
  #15
saemetric's Avatar
drain plug is on bottom of Aisin 6 speed transmission
Old May 7, 2022 | 10:45 AM
  #16
Sorry I mean to say the fill plug
Old May 8, 2022 | 10:17 AM
  #17
saemetric's Avatar
yes it’s buried in there. Easiest way is to slowly fill if thru the dipstick tube. Measure what you take out and refill that amount. Check level with dipstick. 3/8” clear tubing fits nicely in dipstick tube and small funnel. Need about 18” of it. Use correct fluid like Mobil 3309 from Amazon
Old May 21, 2022 | 05:18 AM
  #18
Shelbytucky1's Avatar
I have a 2007 ford five hundred, with the Asian 6 speed, it does have a 12 bolt pan, thought the pan filter was under the pan on the front of the tranny.. But i was wrong, when i took the pan off it was the valve body under it. Went to a part store and got cvt fluid, little did i know it wasn't the right stuff, although it was cvt fluid,. Went to another part store and was informed on it taking a certain type of cvt fluid. and it was suggested to me to add a special additive to it before putting in new fluid. My trans, slipped previously. After that was done another problem came up. Tried taking for a test drive but would not go over 20 mph. and a hole was melted in the plenum from the egr valve, after some research it talked about converters, took them off, was dirty, but i cleaned them and they looked good. Used a flashlight to check them out. Put it back together and it happened again, replaced egr valve and again it happened. At this point i am getting fed up. Any suggestion on my melting a hole in the plenum? Thanks in advance.
Old Mar 29, 2025 | 07:28 AM
  #19
jeffmaira's Avatar
Default 2005 with only 5k miles!!
Just bought a 2005 Five Hundred with only 5k miles.
It was well maintained but would it need fresh CVT fluid due to age as opposed to mileage?
AndrewFL
Jan 1, 2018 04:09 PM
LILRANGER
Aug 25, 2013 08:09 PM
ViMatson
Jul 24, 2013 09:02 AM
pickerbush
Jul 14, 2009 06:54 AM
bushman
Feb 17, 2006 09:39 PM
