Idle limp mode
Old Aug 5, 2020 | 06:31 AM
Johnwcobb's Avatar
Default Idle limp mode
Currently working on 2005 limited. Currently have been told by a shop through diagnostics that alternator needs to be replaced. Question is would bad alternator cause rough idle and when pedal is pressed vehicle stalls out. I have a new throttle body and alternator ready for install but before tearing into it I wanted to get some advice. New to five hundreds. Any help would be appreciated.
Old Aug 5, 2020 | 07:05 AM
It is possible if the alternator is sending out bad signals that are getting into the electrical system.
To confirm this , all you need to do is unplug the alt and see if the problem stops. If it goes away , replace the alt. If not, there may be a fuel supply problem or ign syst problem. Further checks would need to be done.
bluzzer
Dec 13, 2018 08:56 AM
raulg
Aug 29, 2018 06:50 PM
nutter
Nov 8, 2011 10:06 PM
chevyman_1972
Feb 26, 2006 04:22 PM
dykzeulb
Dec 4, 2004 01:24 PM
