vibration dampner removal.
Old Jan 2, 2020 | 09:07 PM
the1driver's Avatar
Thumbs up vibration dampner removal.
2006 ford five hundred 3.0 engine.
How the Heck do you remove this and what tool or specialty tool would be best used?
Old Jan 3, 2020 | 12:57 PM
The ideal way to remove it would include a split wedge type that goes behind the pulley then a long leg puller to pull on the wedge assy.
I hesitate to recommend a puller that just goes behind the pulley with 2 or 3 legs because that can break the back of the pulley and now you will need to get a replacement.
Might be a good idea to check with an auto supply store that either rents or sells the correct tool. Cheaper to buy the tool and reuse the old pulley versus have to fight to get the old one off then still have to buy a new pulley,,,,,,,,if you can get one ! I believe they are vehicle specific because the crank sensor timing teeth are also on the back of that pulley.
DrDialtone
Jun 19, 2012 02:55 PM
dosnotches
Jul 2, 2009 10:00 AM
NC4timer
Jul 9, 2007 06:27 AM
clr0813@yahoo.com
Sep 21, 2005 01:42 PM
