06 500 abs control module not receiving signal
Old Jun 7, 2016 | 09:19 AM
darthrayne's Avatar
Default 06 500 abs control module not receiving signal
I did wheel hubs on an 06 500, and it ended up throwing a bunch of lights after, cel, abs, traction, and the wrench. I ran a dtc scan on it, and after replacing the speed sensor cables I cleared the codes, now I still have one (can't remember number) saying abs control module not receiving signal or something like that.
Please if anyone can help me, it would be great.
Old Jun 8, 2016 | 12:24 PM
darthrayne's Avatar
16 views no replies.... I really need helpl on this. Inspections out at the end of the month
Old Jun 8, 2016 | 02:22 PM
The code number would help. What you might check further is the connecting pins where the sensor cables connect. One of them may not be making contact.
Old Jun 8, 2016 | 02:27 PM
darthrayne's Avatar
Im pulling the code again tomorrow, the actual control modulebwas not touched, just the front wheel speed sensor cables.
Old Jun 8, 2016 | 10:32 PM
primem's Avatar
is this a press in bearing or sealed bolt in assembly?
if its a press in type, did you put the bearing in backwards? One end has a reluctor, one doesn't.
Old Jun 9, 2016 | 04:36 AM
darthrayne's Avatar
It's a hub assembly. And yes, there is a reluctor wheel
Old Jun 9, 2016 | 09:48 AM
darthrayne's Avatar
Code is U0121 lost communication with the and control module. All this happened after in did the bearings. Replaced the speed sensor cables and cleared all code, and still get U0121 after drive cycle
Old Jun 9, 2016 | 07:58 PM
primem's Avatar
which module did the code set in and which module has lost communication?
loss of comm codes will set in working modules...ie uXXXX pcm lost comm with bcm.
so in my example the pcm is working and has lost contact with the bcm...so the bcm is the module to address.
Oct 27, 2021 04:28 AM
bayouwxman
Jun 2, 2016 09:17 AM
Nov 3, 2011 11:24 AM
iward3
Dec 28, 2008 11:12 PM
chuda440
Nov 14, 2007 10:57 PM
