Engine help?
Old Jul 31, 2006 | 10:12 PM
new guy 1's Avatar
Default Engine help?
Hello I have a 2000 ford focus with a 2.0l zetech motor in it and the check engine light came on.Then it started knocking a little and the oil light came on.We pulled the dipstick out and the oil was very pastie and the oil filter seemed really heavy. I just replaced the oil (and filter)and found out that the oil was no more than a quart low.It will start but it misses a little and seems like it wants to stall a little bit at an idle.Its my moms car and she was driving it so I dont know exactly what it did but it hasent been tuned up at all.I think she even has the factory installed plugs and wires in.Do you guys have any ideas what did this (just low oil?),what the motor is going to do or how I can fix it?Sorry to take up your time.Any help would be appriciated.
Tank You,
T.J.
Old Jul 31, 2006 | 10:18 PM
94 4x4 ranger's Avatar
Default RE: Engine help?
what weight oil did you use?
Old Aug 1, 2006 | 10:25 AM
jlhansen's Avatar
Pastie oil, to me, implies water in the oil. It could be a crack in the head/block or blown head gasket (most likely). Do a compression check and a cooling system pressure test. It doesn't look good from here.
Best of luck.
jd637
Feb 22, 2019 08:14 AM
jborushko
Dec 22, 2016 08:06 PM
Bill in Tampa
Apr 27, 2008 09:30 PM
bmwrocks03
Apr 21, 2008 09:29 PM
daveranger
May 24, 2007 12:56 PM
