1995 ford f150 wont start
Old Nov 5, 2019 | 02:24 AM
D1995's Avatar
Default 1995 ford f150 wont start
I need help i have a 95 ford f150 5.8 it staryed running a lil rough then got worse was throwing a black soot out the exhaust well shut it off the other day now it wont start i need help its getting fuel and will crank but no start
Old Nov 5, 2019 | 02:52 AM
I'm pretty sure the fuel pressure regulator is located on the driver's side rear of the engine. It is attached to the fuel rail. There is a vacuum hose attached to the top of it.
If you remove that hose you might see gasoline coming out of it . If so, that is the problem. The internal diaphram has ruptured and it needs to be replaced. The hose is connected to manifold vacuum and the leaking gas is most likely causing the over fuel condition.Held in place with allen head screws.oy may need to remove one or two spark plugs to allow them to dry so they can ignite the extra gas in the cyls. Let us know if that was the problem, thanks.
Old Nov 5, 2019 | 05:16 AM
D1995's Avatar
Thanks this truck is my baby this is the first issue i have had and ive had quite a few of these trucks nver had this issue i will get back to you guys.
Old Nov 5, 2019 | 06:26 PM
D1995's Avatar
I changed the fuel pressure regulater and done my plugs it fixed it fired up and ran like a champ thanks yall im sure ill be asking more questions cuz im slowly rebuilding my truck
Old Nov 6, 2019 | 02:30 AM
Sometimes we get lucky,. Thanks for the update.
ericsalazar_13
Nov 7, 2019 03:53 AM
therealrobC
Jun 11, 2019 01:30 PM
Huntress2u
May 12, 2018 04:16 PM
Rich Robinson
Nov 4, 2016 10:09 AM
dhard
Oct 4, 2010 09:44 PM
