2003 ranger transmission
Old Jan 15, 2013 | 06:53 AM
Tony Remo's Avatar
Question 2003 ranger transmission
I recently installed the transmission in a 2003 Ranger with a 4cyl. The transmission won't go into reverse. Any ideas? Thanks.
Old Jan 15, 2013 | 03:12 PM
Hi Tony,
It does help some if you could tell us if the trans is std or automatic.
Did you do the install yourself or did someone else do it?
Depending on where the replacement came from, do you know if it worked where it was?
Old Jan 15, 2013 | 06:11 PM
Tony Remo's Avatar
The auto trans was rebuilt. I installed it myself. It will shift into forward, but not reverse. Do the two band adjustments have anything to do with this? Ther guy who rebuilt the tranny made a last minute adjustment of them when I picked up the tranny.
Old Jan 15, 2013 | 07:33 PM
I would suspect that either a sealing ring is installed incorrectly or the reverse clutch piston is not applying fully. You may have to have the gentleman open up the trans or at least do a air pressure test to see if the reverse clutch is functioning. Those tests are usually done routinely at assembly time to prevent a situation like this.
jrnc
Jul 11, 2013 07:56 AM
james_glllnd
Mar 20, 2011 03:55 AM
thecsfour
Mar 19, 2009 08:51 PM
adrianweber
Sep 22, 2008 05:13 PM
NeilPage
Mar 21, 2007 07:04 PM
