2019 Ford Edge - Motor Stutters and Backfires
Old Oct 18, 2024 | 02:10 PM
ElloyCar's Avatar
Default 2019 Ford Edge - Motor Stutters and Backfires
Hello Fellow Ford Lovers,
My 2019 Ford Edge is giving me a headache -
Accelerating from zero, the pressure in the air intake manifold at cylinder 4 increases to levels outside of the specificication - and the motor “stutters” - take your foot off of the accelerator and appears that the motor backfires through the intake valve
We replaced spark plugs, coils, and fuel injectors and the problem persists
Can anyone help me with a suggestion? What is the problem and how to solve it?
Thank You!
Old Oct 18, 2024 | 06:59 PM
You think you need help,
I need help . Can you fill me in with just how you knew cyl #4 is over pressurized?
There could be a VVT (variable valve timing) problem. or maybe a different problem.
Would help a lot if we knew what engine, and if turbocharged..
JADEXPAY
Sep 21, 2023 03:25 PM
John a
Mar 18, 2022 09:57 PM
John a
Mar 18, 2022 09:45 PM
unionjackbell
Mar 4, 2013 07:14 PM
johnnydennard
Apr 25, 2011 08:58 PM
