351w efi rough idle/ misfire at idle no power and stall help
Old Apr 20, 2021 | 09:59 AM
Jacobxlt250's Avatar
Default 351w efi rough idle/ misfire at idle no power and stall help
New air idle control valve, rebuilt distributor, plugs and wires, fuel pump assembly, icm, and tps. My truck still struggles to hold idle and just wants to die, there is so little power I can’t even crawl in granny low when is does idle it runs like there are several cylinders missing I’m scratching my head on it fuel pressure at 40 psi while warming up and 35 when at operating temperature.... not sure if that’s too high?
Last edited by Jacobxlt250; Apr 20, 2021 at 07:20 PM. Reason: Not enough information to get a proper response
Old Apr 21, 2021 | 05:02 AM
raski's Avatar
It would help if you listed the year.
Old Apr 21, 2021 | 09:16 AM
Can we ask if the problem was this bad before replacing the dist. ?
If the dist is one tooth off, engine will not run right even though it will run.
Also , when you replaced the cap, if you did, do you have the correct firing order?
frankyv
Oct 6, 2020 08:08 AM
Derrick Calloway
May 15, 2012 10:50 AM
Donald97
Aug 24, 2011 03:29 AM
memphisred
Jul 16, 2011 01:29 PM
agoodname
Apr 23, 2011 05:34 AM
