4.6 triton making noise
Old May 18, 2020 | 05:50 PM
Mid596's Avatar
Default 4.6 triton making noise
hello I have a 99 ford f150 4x4 drive with 4.6 triton it makes this sound at ilde and in drive ilde fine in park once you bring it up to 1500 RPMS you can not hear the sound it makes only at idle I have changed the clutch fan and the ilde pulley still same noise just need to know what it is so I can fix it
thanks in advance
Old May 18, 2020 | 06:16 PM
I don't know if this will be any help, but if we suspect it is something that the belt drives, temporarily remove the belt and start the engine. Only run it a short time (30 seconds) and see if you can pinpoint the source if you hear it. You might get a check engine lite because the alternator will not be functioning.
Old May 18, 2020 | 06:54 PM
Mid596's Avatar
I only have a check engine light on due to the o2 sensor I tried up loading a video but will not let me I post one on youtube under 4.6 make noise my username
I'll try that thanks
GearSpeedKelvo
Oct 19, 2013 10:48 AM
Sneakerwave37
Feb 28, 2013 01:32 AM
J_o_s_h
Jun 19, 2012 08:05 PM
Phil O
Aug 24, 2011 07:59 AM
rusty jones
Mar 9, 2011 02:47 AM
