Abs
Old Nov 19, 2014 | 09:20 PM
sbeamer's Avatar
Exclamation Abs
Is there a "flash" they can do for the ABS brakes? I would either like to make them inactive below 10 mph, or turn them off all together. Sick and tired of going through stop signs!
Old Nov 20, 2014 | 07:28 AM
When the ABS is working properly you don't even know it. There has to be a problem that is causing the ABS to activate. Sometimes it is something as simple as a wheel speed sensor. Unless you are making a panic stop the ABS does very little if anything.
Unless you are coming up to stop signs very fast the system shouldn't activate. Might be a good move to have the system checked out.
Old Nov 21, 2014 | 07:31 AM
sbeamer's Avatar
The ABS is working, no codes. It does activate though, VERY easily. At least on mine.
Hutch64
May 31, 2007 09:21 PM
jessie3
Aug 2, 2005 10:15 AM
gmm
Jul 12, 2005 07:35 PM
Cactus
May 24, 2005 12:59 PM
redfish32
Mar 20, 2005 11:31 AM
