Air Bag Recall- Can a certified Tech settle this?
Old Nov 30, 2018 | 11:20 AM
Carl0s's Avatar
Default Air Bag Recall- Can a certified Tech settle this?
Had airbag recall work done this week on 2010 Edge. Notice battery had NOT been disconnected as I had all radio presets preserved.
QUESTIONon't you have to disconnect the battery to replace defective airbag component on 2010 Edge?
Needless to say there are various opinions ranging from "no you do not need to disconnect the battery" to "Of course you need to..."
I appreciate if some Ford techs could answer this for me. In advance, I appreciate your time and assistance.
Old Nov 30, 2018 | 02:24 PM
Hi Carl0s
There is absolutely no reason you cannot ask the service manager there how they did the recall. He should be able to tell you what the recall involved and how they handled it. Most customers don't care what was done as long as it was done. Good that you care !
Old Dec 2, 2018 | 10:32 AM
Carl0s's Avatar
Since the car is for my kid I am making sure...I asked service mgr and he said you do not need to disconnect battery. My friend at Firestone says you should otherwise this thing might go off as you work on it. It is recall 16S26 passenger airbag. I thought Ford techs would shed some light on this.
Thanks it for your reply.
Old Dec 2, 2018 | 11:25 AM
Some things can be done without disconnecting the battery. As a safety measure , that can be done, but is not always necessary.
Old Dec 3, 2018 | 01:37 AM
Use Common Sense's Avatar
On newer vehicles...Depending on how long the battery is disconnected for, the radio setting will remain intact
Also. if the airbag was to go off, the dirty britches and the airbag is on the Tech..
dragonhunters3
14
May 3, 2023 06:25 PM
Captain B
11
Apr 26, 2023 01:07 PM
Chadholstine
Jan 24, 2017 12:23 PM
jimbobjoe
Mar 6, 2015 02:54 PM
Battery_guy
Aug 14, 2010 12:42 PM
