Coolant in Intake
Old Feb 11, 2011 | 08:59 AM
simon1's Avatar
Default Coolant in Intake
My '95 Crown Vic overheated and I found the valley under the Intake full of coolant. I thought it was the heater pipe which runs under the Intake but that appears ok.Should my next move be the intake gaskets?Anybody been through this? Thanks
Old Feb 11, 2011 | 01:30 PM
Before getting involved in that job , it would be wise to pressure test the cooling system and be sure of the leak location.
Old Feb 12, 2011 | 08:12 AM
simon1's Avatar
I agree with you.However I'm doing this in the driveway and don't have access to all the tools I should.What else do you suppose it could be.Hoses are all good.If not the heater pipe,then how did all the antifreeze get in the valley.doesn't it have to be the intake or head gasket? I appreciate your input,Thanks.The heater pipe is good,and removed.
Old Feb 12, 2011 | 05:04 PM
After being wrong so many times guessing, Even if it takes a little extra work and effort speaking for myself I would suggest you take it someplace that can pressure test the system and remove all doubt.
Old Feb 15, 2011 | 05:25 PM
simon1's Avatar
I'm glad I took your advice.The nipple that the heater pipe attaches to had a hole on the under side.Do it right the first time.Will I ever learn.Thanks Hanky.
Old Feb 15, 2011 | 06:52 PM
simon1's Avatar
Now I'm wondering is this nipple a part of the water pump? It doesn't appear so from the photos Iv'e seen.
Old Feb 16, 2011 | 03:31 AM
I don't believe it is. You may not be able to purchase an exact shape pipe , as long as it is the same size to accept the size hose. I have never had to replace one . Usually when you replace the water pump you just transfer the pipe nipple from the old pump to the new one. If you can't get one , maybe you can get it brazed someplace, I don't think solder will hold.
Old Feb 16, 2011 | 09:00 AM
simon1's Avatar
Boy,it's never easy is it.I'll let you know how it turns out.You've been a great help.Thanks again
Old Feb 16, 2011 | 05:17 PM
This is a great site . I've been in the maintenance field for years and you always learn something new every day.
Old Feb 16, 2011 | 07:58 PM
simon1's Avatar
Yes it is a great site.So glad I stumbled upon it.
