Ford 1994 E150 Econoline Idler and SAI pulleys gone. Why?
Old May 8, 2022 | 03:24 PM
CassDowning's Avatar
Default Ford 1994 E150 Econoline Idler and SAI pulleys gone. Why?
So, serpentine belt broke. Went to replace. There is no idler pulley or SAI pulleys. I didn't know they had been removed and belt was rerouted. Normal size belt for vehicle doesn't fit. Went to replace pulleys. Can't find a dang idler pulley bolt to save my life. I guess my questions are 1. Why would someone remove the pulleys and reroute the belt in the first place? 2. Should I bother putting it back to normal? 3. What size belt do I need if answer is No to question 2?
Old May 9, 2022 | 03:46 AM
raski's Avatar
My guess is someone may have eliminated the smog pump.You should be able to determine routing from looking at the pulley surface.Smooth means the back of the belt and grooved means front of the belt. You could take your old belt to the parts store for sizing. If you want to go back to original, you will probably need a manual or look at the belt route decal somewhere near the core support.
CassDowning
May 9, 2022 03:02 PM
superdave
Sep 20, 2011 12:35 PM
pospman
Jun 21, 2011 04:13 PM
faded247
May 5, 2010 12:00 PM
caserracer
Jul 7, 2007 10:14 PM
