Help with my 99 Ford Expedition Eddie Bauer 5.4
Old Apr 4, 2017 | 03:39 PM
Carol Daugherty's Avatar
Default Help with my 99 Ford Expedition Eddie Bauer 5.4
I have a 99 Ford Expedition Eddie Bauer 5.4 motor I was driving it and it just died on me and I haven't been able to get it started back up and there's no fuel getting to the motor I have replaced the fuel pump the fuel filter check the fuel regulator and the wires and I'm stumped I don't know what else it could be can anybody help me
Old Apr 5, 2017 | 02:06 PM
When you first turn the key on before turning it to the start position you should hear the fuel pump run for approx 2 seconds. Do you hear that? Also, good idea to check the inertia switch and then all the fuses. Inertia switch info is in owner's manual.
Old Apr 6, 2017 | 11:10 PM
Default I will check the switch
I have checked all fuses I'm thinking it's a bad pump I have to pull the gas tank to get it out and replace it again
Old Apr 7, 2017 | 08:14 AM
Because of all the work involved in replacing a fuel pump, before taking on that job again, why not make sure the pump is defective before pulling it apart.
It is entirely possible the pump could be defective, but a good move would be to confirm power is getting to the pump and it has a good ground connection. It is a little bit of work , but not as much as pulling the tank down, especially if you wind up replacing a good pump.
CKH1018
Mar 10, 2011 01:47 PM
Newyorikan007
Dec 28, 2010 07:49 AM
Newyorikan007
Dec 13, 2010 10:04 PM
candicole
Jul 9, 2009 09:51 AM
FordExpy03
Apr 2, 2008 04:13 PM
