Negative battery cable
Old Jul 28, 2024 | 12:30 PM
henryh1's Avatar
Default Negative battery cable
Just wanted to know when I put on a negative battery cable part of it splits off to go elsewhere. Would it be safe to just hook it to any engine ground? Thanks for any help.
Old Jul 28, 2024 | 01:08 PM
MechB's Avatar
Can I get additional information on your vehicle? Yea some go directly to the engine, some also go to the body as well. You have to make sure both are grounded.
Old Jul 28, 2024 | 01:22 PM
henryh1's Avatar
Default Neg battery cable
Hello Thanks much for your quick response. It is a 2003 Ford escape XLT 3l. It's been sitting for awhile. First my alternator went out so I pulled the CV axle to change it just replaced EGR valve, Thought my started was going out, hopefully it is just a starter relay. Been working on that SUV for quite a whileThat starter tested ok while doing the two jump test on it. Got a lot more to work on with that SUV. Thanks again for your quick response!
Old Jul 28, 2024 | 01:57 PM
MechB's Avatar
No problem. It looks like it attaches to the transmission. I'll attach the picture. Let me know
*Forgot to tell you the ground wire is G108
Old Jul 29, 2024 | 07:47 AM
henryh1's Avatar
G 108 looks like it hooks up to the starter bolt but I will check around first. Thanks again!
Old Jul 29, 2024 | 11:14 AM
MechB's Avatar
Your welcome
The picture shows it has its own bolt. However, the vehicle is older, and that cable could've been reinstalled wrong. Like the person or people before forgot where it went and just found a spot. I'd say just figure out a way to ground it however you can, and it'll work.
Captain B
11
Apr 26, 2023 01:07 PM
Pilcrow
May 19, 2022 05:26 PM
Scrapnet
News, Updates and Announcements
Aug 16, 2017 01:49 PM
fordborn
Jun 10, 2013 10:19 PM
