oil leak
Old Jan 8, 2026 | 07:24 PM
3jcontracting's Avatar
Default oil leak
2009 ford F-350 6.4 diesel replaced the HPFP and removed the air in fuel, started as i was moving the truck it started leaking oil from back of the engine a lot of oil. can anybody help me? thank you in advance.
Old Jan 9, 2026 | 10:58 AM
If you recheck your work you might find a gasket missing or damaged
Old May 13, 2026 | 04:46 AM
spilldeny's Avatar
A massive oil leak could mean a component disturbed during the teardown failed to seal Because replacing the HPFP requires removing the entire twin-turbocharger assembly and the engine valley cover, the oil is under direct pressure and will pour down the back of the engine block, mimicking a failed rear main seal.
DickT
Apr 1, 2025 12:24 PM
Iliftw8z
Aug 8, 2024 01:55 PM
Bal
Feb 14, 2024 01:23 PM
greuelc
Jul 12, 2022 07:41 AM
mystique
Jun 21, 2018 08:53 AM
