Smog pump delete on my 97 f250HD 7.5L gas 4X4
Old May 21, 2019 | 08:11 AM
Big Block Fiend's Avatar
Default Smog pump delete on my 97 f250HD 7.5L gas 4X4
So I ordered some hedman headers for my truck and I'm going to delete the cat. But I noticed this pipe going from the cat, to the engine bay, to the smog pump. Is this something I can delete? Could anyone point me towards a delete kit? Or should I just reattach this pipe to my cat delete?
Old May 21, 2019 | 10:34 AM
Welcome to the site..
Its part of the Thermactor Air injection. Basically, 'fresh air' injection from the smog pump. You can't plug the line or the smog pump will fail. If you don't reconnect it, you'll hear the pumps air flow. Sort of a buzzing/woosh sound. If your not smog required, removing the pump etc (although part of the main fead belt drive) and saving the parts may be a better bet. If just the pumps belt is removed/routing altered, condensation/corrosion generally will lock the pump up.
I don't know of a smog air pump delete kit, but an belt idler could be installed in its place if the plan is to remove the pump..
Old May 21, 2019 | 11:03 AM
Thank you for the information, I am not smog required so I will most likely remove the smog pump and replace it with a belt idler.
Old May 21, 2019 | 12:11 PM
If you don't care about the pump,, you could gut the pump of its carbon blades making it not much more than an idler itself...
Old May 21, 2019 | 01:19 PM
That sounds like the best route for me. Thank you
Regb12
Apr 17, 2018 08:01 PM
mrtesty
Jan 17, 2011 11:07 AM
88wright
Oct 9, 2009 02:30 PM
GTI ANGEL
Nov 7, 2006 09:31 AM
351Ranger
Apr 10, 2006 01:11 AM
