Ford freesrar ignition cylinder help
Old Jul 16, 2017 | 06:42 PM
99scslobra's Avatar
Default Ford freesrar ignition cylinder help
Lost my keys to my freestar so instead of getting a new key made I decided to buy another ignition cylinder with 2 programmed keys. while doing the change I broke the anti theft transceiver and ruined the old cylinder, now the car wont start but the question i have is if i get a new key with the chip and have it shaved the same as the new keys and cylinder would the car turn on? or i'm i screwed and need to buy a new ecu, cylinder and keys off another car? thanks
Old Jul 17, 2017 | 09:59 AM
Welcome to the site..
The PATS antenna/reader would need to be replaced,
You should be able to get a 'key-able' ignition switch (changeable pins/bars) from Ford and build it as the OE if you want to stay with alike keys. Or a replacement lock set.. Without the 2 old PATS/chipped programmed keys, it will have to go to Ford or a lock smith that can program them to the system.
The keys don't come programmed..
westfordia
Jan 11, 2013 02:32 PM
gearhead1974
Dec 28, 2007 11:48 AM
jms4138133
May 18, 2007 08:47 PM
itismej
Oct 23, 2006 04:46 PM
vega
Mar 23, 2006 02:04 PM
