Freestar (2006) Not Providing Interior Heat
Old Feb 19, 2024 | 08:26 PM
rose359's Avatar
Default Freestar (2006) Not Providing Interior Heat
My Freestar is not providing interior heat. Instead of the heat control **** rotating from cold on left to hot on right, the **** can spin continuously. I pulled off the **** to verify that the shaft is rotating with the ****, and it is. There is little resistance to rotation - spins easily. Could it be detached from the blend control? Is it electric or mechanical? Anyone have this issue? I need some heat; thanks.
Old Feb 20, 2024 | 06:37 AM
You might want to look at the back of the control ****. . There is usually a flat side on the shaft of the control that indexes with the flat side of the ****. If the **** is cracked it will rotate easily and not move the shaft of the control.
Old Feb 20, 2024 | 11:15 AM
rose359's Avatar
hanky:
Thanks for that; I did confirm that the flat of the **** (not cracked) is on the flat of the shaft. When I pull off the ****, the shaft is very easy to rotate without the ****. It seems odd that the shaft rotates continuously; I think typically there are stops at full Cold and full Hot.
Old Feb 20, 2024 | 12:55 PM
You may need to replace that control.
Old Feb 21, 2024 | 03:19 AM
rose359's Avatar
Default Replace how much?
Can I replace just that temp control, or the whole unit including the fan control and the heater/defroster selector?
Old Feb 21, 2024 | 11:11 AM
The control is usually available at a dealership parts dept., but some auto supply stores like NAPA may have one available also, need to call them and check.
Old Feb 21, 2024 | 12:01 PM
rose359's Avatar
How much needs to be replaced? On Rockauto, I see this part. Is it what I am looking for?
FORD > 2006 > FREESTAR > 3.9L V6 > Heat & Air Conditioning > Heater Air Door Actuator
Old Feb 22, 2024 | 01:15 PM
The control is a separate part from an air door actuator.
Suggest you call them and verify that you both are talking about the same part..
That is the benefit of going to the place and see just what they try to sell you If you buy on line and get the wrong part, happens often, been there now you have more problems than when you started. If you have no experience taking a sash apart,might consider having a good shop do the job.
Old Feb 23, 2024 | 02:40 PM
rose359's Avatar
I am no stranger to tearing into dashboards, I was just hoping to determine if that is needed. The blend door actuators are above the accelerator pedal, but the heat control is in the dash. This problem has become intermittent, so I may be searching for a loose connection.
arff2108
Jun 22, 2021 11:36 AM
cleocutie
Oct 16, 2017 03:34 AM
jmil67
Feb 26, 2015 12:23 AM
mssief
Mar 24, 2013 12:35 AM
robinas4
Jan 26, 2009 09:44 PM
