Freestar Steering Wheel Stuck
Old May 30, 2020 | 06:40 PM
Joe_Cooler's Avatar
Default Freestar Steering Wheel Stuck
Trying to remove the steering wheel. I backed out the retaining bolt from the access panel on the bottom side of the wheel. It hit a sticky spot and I powered thru it. I unscrewed it at least 120 turns and it just spins freely now. The wheel is still solidly mounted. Did the worm gear fail? Any other way to get that gear off? I think I may need a new column. Anyone else have the problem? Was gonna replace the clockspring. Thanks in advance...
Old Jul 22, 2020 | 03:38 AM
kalbok's Avatar
I had the same problem and I got to change my steering wheel. It was quite expensive, so I decided to restore it. It took about two weeks, but it solved my problem . here is the link to their website Woodensteeringwheels.com. Hope it helps! Drive safe and good luck m8!
Old Mar 27, 2024 | 07:18 PM
marcolin2's Avatar
Joe
I'm having the same problem... Do you recall how did you resolve it?
Thank you
bigyinnorth
Dec 11, 2013 02:14 AM
jlitman69
May 17, 2012 03:45 PM
taylorme63
Mar 2, 2010 12:22 PM
fordfan
Jan 15, 2008 12:40 AM
oscar7777
Sep 6, 2006 09:08 AM
