Rear coil springs 04 Freestar
Old Dec 30, 2016 | 07:39 PM
Justdave's Avatar
Default Rear coil springs 04 Freestar
How come I can't find any after market coils springs for a 2004 freestar limited? Only place I can find them is at the dealership.
Old Dec 30, 2016 | 07:52 PM
By the time you find someplace else to get them, it might cost more than if purchased from a dealer.
And they should be the correct ones.
Old Dec 31, 2016 | 02:29 PM
Justdave's Avatar
173.00 each from the dealer. I think thats way over priced for just a rear coil spring. I'm changing the front struts and springs today and I only paid 158.00 for two complete strut assemblies.
Old Jan 3, 2017 | 04:20 AM
Use Common Sense's Avatar
If you want to upgrade your rear springs for a slight lift and a little more weight capacity, then I would go this way (From my Freestar library)
FREESTAR Rear Spring Upgrade
The following coil springs will fit the rear coil spring brackets on the
Ford Freestar/Mercury Monterey for upgrading the weight capacity.
1990-1996 Bronco (Front Coils)
1975-1991 E-150 (Front Coils)
1980-1996 F-100/150 (Front Coils)
MOOG part number CC820
AC DELCO part number 45H1024
ROCKWELL part number RV820
All are sold in sets and probably range from about $75-100 per set.
Old Apr 27, 2017 | 03:32 PM
DAB6's Avatar
I opted to buy and install aftermarket coil airbags that fit inside the coils and are adjustable via air pressure. I got them off e-bay for about $75 and they have been working well for the last 4 years. When I have the trailer on I pump them up to 30 lbs and the van stays level and reduce the pressure to 5-10 lbs when the van is empty. A simple option if you don't want to go with OEM springs. Additionally, you could try RockAuto.com as they tend to have OEM and aftermarket options to cover the price points.
DB
Old Mar 17, 2025 | 11:03 PM
Bond007ria8's Avatar
Which ones of the 6 is the better pair?
Default 2004 Ford freestar coil spring
Which ones of the 3 is the better pair?
Old Aug 30, 2025 | 09:14 AM
Wazmontez03's Avatar
I have also been curious about this exact topic. I soon plan on installing a receiver on my 05 Limited, id say look on ebay, amazon, even walmart online. I have looked it up and they have them, check it out.
Old Sep 1, 2025 | 11:48 PM
well, its not 2016 anymore and were in 2025, 9 years later these are nowhere to be found, i custom ordered my springs from a sping company, came out to about $580 with installation, $480 for the coils, but, i tell you this, no more jumping around and the van rides great, no more bottoming out, i can load it and it goes down to original height, its about 3 to 4 inches higher when empty, otherwise good
coilsprings.com ask for Kevin
2005 Mercury Monterey
Rear - +2.00" Trim Height - constant +1000# Cargo - non constant
Pricing; $ 428.20 pair
Shipping cost; $ 52.60
Total Cost : $ 480.80
Refer to Quote# 43627 when addressing this vehicle.
this was just done in april of 2025, so this is very up to date information, hope this helps
Old Sep 1, 2025 | 11:49 PM
djripper
Apr 26, 2020 10:32 PM
smity30
Jul 1, 2013 04:15 PM
ralfs04freestar
Aug 30, 2011 01:19 PM
ljcorby
May 5, 2009 11:15 AM
kmracing
Jan 29, 2009 07:03 PM
