Ford Freestyle The new crossover, combining the versatility of an SUV with the compact size and feel of a station wagon.
water leak
Old Dec 26, 2007 | 07:28 PM
wes05's Avatar
Default water leak
MY 2005 Freestyle has water leaking onto the floor of the passenger side front and rear carpet. The car is off of warranty and I would like to repair it myself but I can't find the leak. Anyone had this problem? Any suggestions on how to find the leak?
Old Dec 26, 2007 | 07:34 PM
wes05's Avatar
Default gear shifter problem
MY 05 freestyle gear shift sometimes can not be moved out of park. I have to remove the console and and press a button inside to release it. I have tried lubing everything that moves but it still does it. Does anyone have a fix for this?
Old Jan 15, 2008 | 08:43 AM
oldtimer35's Avatar
Default RE: water leak
The shifter problem is probably the shift interlock which is part of the shifter assembly. I would check fuses and make sure my brake lites work, as it is tied into that system. As for the water leak into both front and rear of the vehicle, I would check under the carpet and padding on the passenger side toe board, where the washer line for the rear enters the passenger compartment, the boot may be out of place.
Old Mar 7, 2008 | 12:18 PM
mkaresh's Avatar
Do you have a sunroof? A plugged or crimped drain line is often the source of such a leak.
jec65
Oct 20, 2019 08:33 AM
DAM4
Jul 28, 2007 11:54 AM
kyford
Dec 31, 2006 05:17 PM
danny88
Sep 24, 2006 06:34 PM
mi97tbird
Nov 27, 2005 07:27 PM
