2013 Fusion ABS Control Module
Old May 1, 2023 | 02:28 PM
bedsmom's Avatar
Angry 2013 Fusion ABS Control Module
The ABS system went out on my daughter's car and we are having a hard time finding a control module for the ABS system. Originally there was one part on the car, then Ford split it into 2 parts-a control module and a modulator valve. We can find the Modulator Valve but not the Control Module and Ford says they have no idea when more will be produced. Does anyone know if you can replace with a junk yard part and re-program?
TIA
Old May 1, 2023 | 04:06 PM
raski's Avatar
Yes your junkyard option will work.This site will help you find a Fusion in your area.
www.car-parts.com
Old May 1, 2023 | 06:56 PM
Car parts.com is affiliated with parts geek and a few others.
If you order something from them make sure you won't mind returning it for the right part. Went through a lot to get the right part. They are pleasant to deal with .
Hope you have better luck than I did.
Old May 2, 2023 | 03:08 AM
raski's Avatar
You are misinformed about the parts geek stuff or what your definition of a parts geek is..It is not used by private parts owners looking to sell parts online like Craigslist.. .. It is an easy way to locate parts from salvage yards in one's area without wasting gas and time with phone calls.
Old May 2, 2023 | 10:33 AM
Let me tell you how this happened.
I originally was looking for a particular part for an older vehicle ign system.
I saw the part they showed would fit the vehicle in question when the info was submitted.
I placed a telephone call to order the part. The guy taking the order was located in the Philippines. Very pleasant. When part arrived , wrong part Called again, same place .
rec a return authorization. Promised to send correct part . Second time , wrong part. After 3 attempts , received a part that I had to alter to do the job.
So far still waiting for credit to be applied to my credit card almost 3 months now. Maybe ,,,,,,,,I was misinformed, but I did learn a lesson from speaking with the gent from the Philippines at least twice. As I stated they seem to be a good company , but I finally got tired of returning wrong parts.
That gentleman was the person who told me the compamies/businesses were related.
Old May 2, 2023 | 12:22 PM
raski's Avatar
What does that have to do with the OP's problem and question? Absolutely nothing. You have to stop drifting off subject and criticizing my suggestions.
Old May 2, 2023 | 03:38 PM
This is not a place to get personal. But in response to your request, I would gladly ,,,,if you will too, thanks.
petermb72
Sep 25, 2021 11:29 PM
SuperShawn
Apr 6, 2021 07:50 AM
Monty51
May 17, 2015 12:16 AM
petec
Oct 20, 2010 10:16 AM
jrouse
Dec 14, 2006 12:55 PM
