2014 Ford Fusion Cylinder 4 misfire with additional codes
Old Jul 14, 2020 | 03:18 PM
James Walter's Avatar
Default 2014 Ford Fusion Cylinder 4 misfire with additional codes
Hello all
Recently had my Fusion start to act up ( 2014 Ford Fusion SE 2.0 Ecoboost).
Originally had only a misfire cylinder 4 fault pop up. Initially thought spark plugs, no big deal. After swapping, the code persisted and add a CPS fault to the list. Swapped the CPS and those have gone away. Now I'm back at the cylinder 4 misfire.
I've got sluggish acceleration to downright skipping a beat when doing quick acceleration. Occasionally I'll hear a ping but only when attempting to merge for highway speeds and then still only every now and then. It was idling at 60% engine load till this morning when for no reason that got cleared up. However it still bounces between 400~-1000 rpm at parked idle. Drive idle is more like 300~-700 rpm. Went to pick up a fuel injector this morning thinking this was the next logical step. Pulling into my parking spot I got a 1 or 2 second notification of low oil pressure. Pulled the dipstick and smoke came out of the dipstick hole for a solid 30 seconds if not a little more before it cleared out. Got the car home and let it sit for roughly and hour and a half, dipstick came back clean after wiping.
Any ideas? I've been told thus far that it's either the PCM, piston rings or turbocharger. Really not trying to spend an arm and a leg and do all three by chasing down the problem as I don't have the money to do that.
NOTE: the ignition coils seemed ok and I noticed no problems with the spark wires or engine harness but didn't tear it all apart for a full review.
Expl14
May 27, 2019 06:48 AM
colorfulpoet
Apr 22, 2019 04:40 AM
DanNeedsHelp
Mar 28, 2015 08:07 PM
Shipwright
Jun 1, 2013 01:31 PM
skip1930
Jan 26, 2013 05:19 PM
