2016 ford fusion se power steering
Old Jun 17, 2023 | 07:43 AM
Dwatters0707's Avatar
Default 2016 ford fusion se power steering
I just bought the car yesterday for a decent deal due to it having steering assist advance track and traction control error on screen. I plugged in my obdlink sx and scanned for the codes with forscan. I can't see the power steering module at all. No errors and no codes pointing to it. Do I need a newer adapter that can hand the mscan bus to be able to access the module?
I'm trying to see the error it has so I know where to start on repairing the steering. Right now there is no assist at all. Also is there any other fuses for it on this model other than the one 10amp under the hood?
Old Jun 17, 2023 | 10:38 AM
You might check for` power and ground available at the PS motor.
Old Jun 17, 2023 | 07:10 PM
Found the fuse for it and it was OK. Also power/ground at the motor. I'm still not getting any communication with it. It seems like I'm not getting communication with a few modules. I can see the pcm the bcm the park assist and the tpms system plus another module or two. I cant see the abs the pscm I don't get the option to program keys or anything so seems like I'm not seeing the security parts either.
I have a new adapter coming in tomorrow but this car did have a minor impact in the front passenger corner. I kind of wonder if there is and can network wiring up there. I'm just at a loss with it now since I can't see any of those modules or their codes. I have drove the car the last two days with no issues other than the power steering out, advance Trac light, traction control light and hill assist lights on
Also if I remove the 10amp fuse for the pcsm I do get an error that the bcm lost communication with the pscm
Old Jun 18, 2023 | 05:07 AM
We should find out why the other warning lights are illuminated.
Power strg may be the result of another problem.
Old Jun 18, 2023 | 07:13 AM
That's the plan but I'm not able to see those modules to be able to pull code from them.
Old Jun 18, 2023 | 02:49 PM
new scanner worked fine and gave me access to all modules. error code for the PSCM is for the steering torque sensor 1. is thes replaceable or does it require an entire rack and pinion?
Old Jun 19, 2023 | 06:07 AM
It is replaceable, but must be programmed to the vehicle.
Old Jun 19, 2023 | 06:11 AM
Have a link that I can find one? I can only find the pscm not the torque sensor on the steering shaft.
Old Jun 20, 2023 | 09:01 AM
Replaced the full rack and pinion due to not being able to find a replacement torque sensor. $90 for a rack with 25k miles was a steal and the car now has no codes.
Cyprus2400
Nov 7, 2022 05:55 AM
AlanJ
Oct 18, 2021 07:35 AM
Denblake
Sep 19, 2019 09:36 AM
chife007
Sep 18, 2009 09:06 AM
skuntz01
Sep 7, 2009 08:17 AM
