fusion ac clutch won't engage unless bypassed
Old Sep 4, 2017 | 11:56 PM
ejskippy's Avatar
Default fusion ac clutch won't engage unless bypassed
My '12 fusion ac clutch doesn't engage unless the relay is bypassed.
I previously replaced the hvac control module. I just replaced the evap temp sensor and relay. Any ideas?
Old Sep 5, 2017 | 05:47 AM
Part of the compressor control system uses high and low refrigerant pressure switches which are to protect the compressor if the pressure gets too high or the amount of refrigerant in the system is too low. The best thing to do is check the amount of refrigerant in the system with a set of A/C gauges. If the pressures are good then an electrical problem may exist.
jimbobhog
Feb 3, 2016 04:28 PM
davetully
Feb 24, 2013 05:51 AM
yayeer
Jun 12, 2012 11:44 AM
helpmyford
Apr 7, 2010 01:03 PM
Salvatorparadise
Apr 4, 2007 02:13 AM
