P0340 and P0344 engine codes
I recently replaced the timing chain on my 2013 Lincoln with the 3.7L, V6 engine. The car started up but threw a P0340 and P0344 engine code. I replaced the two camshaft sensors, but the codes are still there. If the timing was off, the car would be throwing way more codes, am I right on that? Do you have any pointers on how to fix this issue? What fuses do I check that run the camshaft sensors? Any guidance would be greatly appreciated. Thanks
12V or 5V reference voltage doesn't matter, it gets from the PCM, not a dedicated fuse. So simply recheck the connection and wiring between your PCM and the sensors. Use voltmeter and ohmmeter to verify.
Vincent Jones
Jun 22, 2023 05:33 PM
