I have a 2015 Ford Fusion. There is a black/translucent panel on the front passenger window frame that is de-laminating. Does anyone now what this part is called and if it can be replaced without replacing the entire door?
It’s called the front door ‘upper moulding’. It can be replaced with basic tools and isn’t a larger task. If you want to do the job yourself, i can send you the images steps...
