Hello everyone,
I have a 2011 fusion that the radio only works in accessory mode. As soon as I start the engine, the radio will turn off in about one second after starting, and when I turn the engine off, the radio comes back on. I checked all fuses that are related to the radio under the steering column, and everything looks good. Research has pointed towards a possible bad ignition switch? Something to do with switching from accessory mode to run mode. Any suggestions helpful.
Nothing within the past 3 years has been changed to the vehicle. My wife did mention within the past few months that the radio would go off and then back on.
A questionable connection supplying power to the radio would need to be verified by checking the voltage available to the radio and observing if it fluctuates when the problem shows up..
Not difficult, but would require a voltmeter and tapping into the wire AT THE RADIO.
If any change is observed, we know it is between the fuse panel and the radio.
If no change is observed, the the problem is within the radio itself..
BCM (body control module) is involved in operation of your radio so you need to find out whether it's the BCM or the wiring between your BCM and your radio.
1) You need a Ford specific scanner like (Foxwell NT510 Elite w/ Ford) to retrieve the DTCs associated with BCM.
2) If it's just the wring after the BCM, you need to remove the radio and test the connector in the back when it's in ACC or START for 12V. Of course you need a diagram for that, and you also need a multimeter.
I don't have diagram for your 2011, just 2007 shown above, you can clearly see a dedicated F22 fuse (Hot in Start) to terminal 15 of your radio. Just an example only, 2011 is controlled via BCM you just need to have a capable scanner to find out the DTCs and see what is going on, and reset or fix if needed.
Additionally, you said you tested the fuses, how? Just visually or with a multimeter? How do you know for sure your F22 fuse (for example) is good? A simple continuity test by probing the 2 tiny terminals on top of the fuse (without pulling) can do it, if you know how to check resistance you can get more accurate result than continuity check and expect 2 ohm or less. Don't pull any fuse if at all possible, if you must pull certain fuse, you should disconnect the battery ground cable first.
