Transmission Ford Fusion SE 2018 1.5L
Old Aug 3, 2022 | 08:58 AM
coroneljo's Avatar
Default Transmission Ford Fusion SE 2018 1.5L
So driving in highway traffic in and out of traffic houston tx i45 and i broke and accelerated cause you know traffic. The transmission kicked/skipped or what ever. Wife said it happened to her once yesterday. Its got 51k got it with 23k a year ago, any advice or what it could be? How can i fix it or something, i plan to have it till i finish paying it. Its been a great car and im not a big fan of ford except for the powerstrokes.
Old Aug 3, 2022 | 10:20 AM
raski's Avatar
I would check for codes first.
Old Aug 3, 2022 | 10:59 AM
Did you ever have the trans serviced?
Old Aug 3, 2022 | 11:44 AM
raski's Avatar
Fluid and filter changing is not going to help their symptom considering the vehicle only has 51k miles. There's something else going on. The engine may be possibly exhibiting an issue. A more in depth diagnosis is needed to track this intermittent problem down.
Old Aug 3, 2022 | 12:04 PM
coroneljo's Avatar
no, i thought it should be when it got more miles
coroneljo's Avatar
How? Theres no codes on the dashboard
Old Aug 4, 2022 | 11:45 AM
Expecting a fluid and filter change to correct possible internal trans problems is somewhat short sighted.
On some trans there is no way to check the level other than on a lift or having the vehicle up in the air.
What we do look for are traces of excess material in the pan ,or even parts in the pan. We don't know some things until we look.
If and when a valve in the valve body sticks/hangs up a malfunction is assured.
If that excess foreign material does get into the valve body , it can cause problems and is important to prevent problems up the road.
Old Aug 6, 2022 | 03:56 AM
raski's Avatar
If there is a lot of debris in the pan or filter, plan on an overhaul. There shouldn't be much debris after only 51k miles.
Old Aug 6, 2022 | 12:35 PM
Why do you suppose Ford recommends changing the trans fluid every 30,000 miles on the 2018 Ford Fusion ?
Old Aug 6, 2022 | 01:31 PM
raski's Avatar
30K would apply if the vehicle is used under severe driving conditions, otherwise 150k under normal driving conditions. I don't agree with 150k but that's what is in the manual.
Keith63
Feb 24, 2019 11:33 PM
nmdoc
Jul 8, 2014 02:37 PM
aziljesani
Oct 15, 2011 09:23 PM
aziljesani
Oct 15, 2011 04:45 PM
Fusion41
Apr 2, 2010 12:46 PM
