transmission/Speedo not shifting properly
Old Aug 18, 2018 | 03:57 PM
RET3's Avatar
Default transmission/Speedo not shifting properly
2008 fusion SE Each time the car is started the transmission will stay in first gear for an excessive amount of time / rpm. The Speedo will not register any speed until the transmission shifts to second. Then Speedo registers just fine and shifting returns to normal. Immediately it throws two codes. One for transmission speed sensor and one for transmission output speed sensor. I have replaced the trans speed sensor and cleared codes, no change. The part stores don't even show a part for trans output sensor. Each time the key is cycled off /on this pattern stats again. Any suggestions. The car did not have this problem until my daughter continued to drive in a massive down pour that she probably should have pulled over and waited out. It has been like this for over a month. At first intermittent and now with each key cycle.
Old Aug 23, 2018 | 06:13 AM
The trans should have 2 speed sensors.
Input and output, one mounted on the top of the trans and one mounted on the side.
Which one did you replace?
Old Aug 23, 2018 | 08:59 AM
RET3's Avatar
I replaced the one on top. The parts stores don't even list a part number for the output speed sensor. Is this a ford only part?
Where abouts would this output be located looking at it from normal position standing in front.
I've located the trans speed sensor (on top), the input sensor located in front side near what would bell hell housing, then the PRNDL switch/sensor is about mid way to driver axle on the front side. I still haven't located the output. I'm assuming it would be on the driver axle, but I guess it could be from under the car on the pass axle??
Old Aug 23, 2018 | 09:06 AM
RET3's Avatar
Just watched a you tube video. It is on under side on pass axle.
Old Aug 24, 2018 | 06:32 PM
RET3's Avatar
Update for those that might have a similar problem.
Once I got the car up on a rack, I pulled the sensor on the passenger axle housing. By the way it's the same sensor as the one up top. It had about 4 cc of water in between the sensor and the wire pigtail. Went ahead and replaced it just because I didn't want to go back and forth up on rack. I'm sure once I dried the original sensor it would have worked. Anyway cleared the codes and trans shifting and Speedo acted normal immediately. Problem solved.
louierg
Dec 3, 2017 05:41 PM
joepenn
Aug 8, 2011 06:55 PM
tennesseesaturn
Oct 18, 2008 06:51 PM
jerry81_99
Sep 9, 2008 04:04 PM
bradleyj
Feb 21, 2007 07:09 PM
