V6 99 Mustang cooling fan does not work
Old Aug 14, 2022 | 05:44 PM
JigumsFrom.HR's Avatar
Default V6 99 Mustang cooling fan does not work
I have recently purchased a 99 mustang and have found that my radiator cooling fan does not turn on, upon further investigation I have also found that I get no power to the fan, and I also tested for power through the CB fuse in the fusebox and I don't have any voltage running through that with the A/C on either, what could be causing this?
Old Aug 15, 2022 | 06:14 AM
Without checking myself, I would suspect there are cooling fan relays.
If you look in your owner's manual , you should find a diagram showing the number and location.
Power needs to be verified at the switch and getting to the relay when requested. If power and ground are present when required, isolate the fan from the circuit and supply power directly to the fan, that will tell you if it is in working condition.
nwachai
Jun 1, 2021 06:45 AM
PHOKiS
Apr 24, 2021 09:20 AM
Fordowner2356
May 8, 2020 04:22 AM
dang482001
Jun 29, 2007 10:36 AM
fairstang1
Nov 13, 2006 02:32 AM
