'04 Has slight studder at take off
Old Jul 29, 2006 | 05:03 AM
kruzer022's Avatar
Default '04 Has slight studder at take off
I just bought a 2004 Ranger, FX-4 Level 2, 4.0, Auto, and have noticed a slight vibration when I go from a complete stop. Is this normal or is it something I should have looked at?
Thanks
Old Jul 29, 2006 | 11:38 AM
94 4x4 ranger's Avatar
Default RE: '04 Has slight studder at take off
I would bring it back. It does not sound like a minor problem.
Old Jul 29, 2006 | 01:21 PM
Mulletman's Avatar
I have encountered this on a few Rangers. Turns out the driveshaft was needed to be replaced to fix them.
Post your VIN# here and I will run it through the system for you.
Old Jul 29, 2006 | 03:13 PM
kruzer022's Avatar
VIN #: 1FTZR45E54TA18460
Old Jul 29, 2006 | 04:26 PM
kruzer022's Avatar
Is there any chance this could have somthing to do with it having limited slip?
Old Jul 29, 2006 | 05:21 PM
Mulletman's Avatar
DEALER: Tincher Ford-Mercury, Inc.
WARRANTY CLAIM NUMBER: 058386 ODOMETER: 013026M
F5TZ 7M101A SENSOR TURBINE SPEED 001 7000F3 42 DOES NOT OPERATE PROPERLY
XT 5QM 004 7000F
000 7000F2
PERFORMED EEC TEST CODE P0721 COMPLETED TRANS DIAG PINPOINT TEST FOUND OPEN IN TUBINE SHAFT SPEED SENSOR R&R TRANS REPLACED TURBINE SHAFT SPEED SENSOR
The trans was looked at as you can see and a repair made for something. I did not find any other info for you at the moment.
The limited slip rear may exhibit some, but not a bad sensation.
Old Jul 29, 2006 | 08:18 PM
kruzer022's Avatar
Made an appt for monday to take it in to the dealership and have them look at it. Anything specific I should request they look for?
Old Jul 31, 2006 | 01:23 PM
kruzer022's Avatar
Took it in today to the local dealer and they hooked it up to the computer. The computer said that everything was operating properly. They told me that this was normal for all Rangers with this package. It still feels wrong to me, but I guess I need to go in and test drive a new one and see if it does the same thing.
2THPIC
Jan 2, 2020 11:37 PM
ahooten
Jan 17, 2010 04:59 PM
joe72777
Apr 30, 2008 06:10 PM
explorergirl2
Apr 13, 2006 12:22 AM
ghight
Sep 2, 2005 07:31 PM
